I did get my VP SLW's (1" wide version) with 350 spacers all mounted. I mounted a pair of new Panthers and a pair of white Rovers, both with stock Losi grey foams. I will be running these in the rear and have a set of different rims I will be running in the front.
Here is a pic of why I want/need aluminum rims....
and from the hex side.....
The cool thing is the VP SLW's are less than .5 ounces heavier per wheel than the stock Losi plastic rims. You can get super narrow, too, if you want (see below).
Here is a stock Losi rim, outside of beadlock to outside of beadlock, with thin Axial hexes (about 9 1/8") on the back of my Losi axles.
Here is the VP SLW with .350 adapters. You can go down to a .225 spacer, effectively narrowing by about 1/4" overall. Right now they are at about 8 5/8". The fronts hit the knuckle with the Axial thin hexes, but with stock Losi hexes, there is just enough clearance (less than 1 mm). Hope this is not too narrow, but we will see. This width will be run in the back with standard Axial offset wheels in front.
Here is a pic of the rims with the Panthers mounted up. I do like them, usual VP quality. Though I am a bit confused as to why they went with metric beadlock screws and standard spacer screws....just stick with standard screws like the VP DH Pro's I have.
Here is the rear width with the Panthers all mounted up (under 9 3/4").
