Well I still haven't actually taken her out so I don't have any action pics yet, but I've been making a few changes to finish off some details..
I had a chrome (read: ugly) servo guard/skid plate gathering dust on the bench so I scuffed it up, shot it with a few coats of the olive green I've been using and slapped it on there. It was made for a 10.2 but bolted right up to the 2 front-most holes on the frame rails. It pushes the fender liners outboard by a hair but it doesn't cause body rub or anything..
It's arguably a pretty useless part, I can't see it coming into play very commonly. But I think it looks pretty good and who knows, maybe I'm wrong about it's usefulness..
And I really wanted to run a winch on this rig and make use of the fairlead that's molded into the bumper but keeping the winch under the body would be key since you can't adjust the front bumper position as it's part of the body mounting system..
I noted that the front bumper mount had some unused holes on the bottom side so I flipped it over to be able to make use of them and there's a good bit of room available in front of the servo/motor. With those things established, it was a simple enough task to draw up a little mounting plate. The winch had to positioned off center because I just used a generic "warn-like" winch and the motor enclosure is off centre. You'd have to use an 8274 or maybe a servo winch to centre it properly..
I cut the plate from .080" aluminum on a water jet and I'm pretty satisfied with the results. I might pull it off and shoot some flat black on it one of these days but that's pretty low priority since it can't be seen when the body is on and it's currently -17C in my garage..
For the finishing touch, I made a custom fairlead (my local group is called "Kelowna Trail & Scale") and bolted it over top of where the molded one was on the stock bumper. I widened the slot in the bumper a little as well to match up with the fairlead better..
The winch I picked up came with a fancy thimble/shackle doodad that I initially thought was pretty cool until I saw it installed. It just seemed really "sticky-outy", so I switched to a regular black hook with a winch saver instead but apparently I forgot to take a picture of it. I also swapped out the wire line it came with for some 200lb test dyneema fishing line, I think I spooled about 8ft on..
This picture's only here because that receiver box is a bit of a personal milestone, this is the first time I've ever used more than 3 channels. I was quite pleased that I was able to cram it all into the stock Rx box..
