Vanquish Products SLW
Vp Monkey
Vendor
sacramento
Vanquish Products SLW wheels are now avalible for preorder, they are not quite done but we expect to fill most orders as stated on the site. If they are done earlier shipments will ship in order of placed orders first "thumbsup"
I tried to get all info in there, we will update more info as the questions roll in.
Cheers
Thomas
http://www.vanquishproducts.com/vanquish-productsslw.html
Very have added SLW .7 and .5 wide.
and adding SLW-NT .7 and .5 wide
Very nice and better priced then I thought they would be. Considering replacing my VP DH Pro's with these.......or at least 1 set of them:)
is that 9.5" from outside beadlock to outside beadlock on a berg and on fornt axles w/vanquish knuckles ?, if so, thats great! "thumbsup"
we are adding a fifth smaller offset that will measure 9.5 from wheel to wheel on a berg.
Will that work for the front too or is that for the rear with the knuckle arms cut off only?
I need to physical check the fits to be 100 percent sure for the 1.3 wide, but i 99 percent sure the 1.0 will be good front and back., I beileve the 1.3 will be good on back.
we are getting finished production wheels off today I will post when I gather up the info, and for those that preordered, you will be able to adjust the order if you want the 225's instead.
that is to the wheel, we need to add .1 per side to include the beadlocks, soory for the confusion, so it will be 9.7 on a stock berg.
I've had a set of these for a couple of weeks now and with Worlds right around the corner, I've been on the rocks a lot.
I love them. I'm doing lines so much easier then before, not having to pull all the weight up the rocks have made a big difference.
Thanks VP...... "thumbsup"
Did you drop your front weight to keep the ratio from front to back the same...or did you just keep the front the same weight? "thumbsup"
Exactly what is this measurement on the Berg?
1.000 wheel to wheel Inside measurement = 7.76
1.350 wheel to wheel Inside measurement = 7.06
See that the decription says Price Includes the following, 2 Wheels, 4 beadlocks, 2 Hubs, 12EA. 4-40x3/8 SST SHCS, 24EA. M3x6 SST BHCS, but it also says *** BE SURE TO AD A SET OF SLW HUBS TO YOUR ORDER OR YOU CAN NOT MOUNT THE WHEELS***. Which is it?
Price Includes the following, 2 Wheels, 4 beadlocks, 12EA. 4-40x3/8 SST SHCS, 24EA. M3x6 SST BHCS.
i had a typo, we reconfigured hundreds of things on the web site i had some bugs.
i dont understand your question on the inside wheel measurements, do you need another decimal place ? :)
