XSRCdesign
the 1.9s look funky?
Well I finally got the tires all mounted :roll: The SSZ's look so damn good but are twice as hard to mount tires. One gave me a big fight but the other three were pretty easy.
The truck is back to rolling, although it is rolling rough. I noticed it looks like I have 2 or three bent XVD pins now. I can't remember which ones are drill blanks and which were stock. :x
Can I suggest something Josh. Ace Hardware has Piano wire. I have had nothing but success with them in the teeny. But obviously the Wraith you have has a bit more torque.
I only hope that SDSCustomz gets those 300's soon. Nothing against RC4WD, but I am really surprised that they made them weak in the middles and not as strong as I expected them to be.
BTW, I have a spool and winch line coming to you now that the store is open again"thumbsup"
When you get 1.9's mounted up, can you post up the height of them ?
Nice Build, I wanted to make a note about the CVD's from rc4wd. I have broke two pair so far as well as snapping the stock axle shaft off at the ball. I assume this is attributed to wheel weights, turning degrees and power. Since the last time I snapped an axle (about four battery cycles) I have removed all the weight from my Vanquish DH's and turned down the degree of turning ability.
i think i will change the pin of mine before mounting them as you did on yours...
