Mine are definitely the rears but I used a some different springs to lower the ride height.
A 70/30 setup with the rears would be a fantastic setup. Definitely better for crawling, maybe not as much for speed.
Lucky me, the stuff from DLUX showed up as well.
Are you able to share links to some of these vendors please? I can't find DLUX even with a Google search "thumbsup"
Hi harley, what do you thing about installing short proline shock an the front and the long ones on the rear? can this configuration due some problems on runnig?
PS. thanks for your unique source on wraith mod!!!
If you already had a full set then you could definitely make it work. However for me, most of my weight is in the front (moved my battery up there). So I would probably run the longer shocks up front and play with the springs to level the ride height.
I prefer to have more flex in the front for crawling so that would likely be a good setup still.
mmm...long shock on the front and short on the rear....this can be a different idea for a new shock setup.
also in mine the battery is moved on the front, just at the end of interiors, i have not control the weight difference between rear and front, but it can be a nice idea....
what do you think about a 3/4 droop set up taking off the short spring from the shock?
HeyOK HV Winch switch on its way."thumbsup"
I beat on this rig HARD yesterday while testing the XVD's at the NSCA comp. I was running through large rocks and rip rap which people who have been around while know how hard that is on a truck.
After about a pack of running I finally had a failure, but it was only a spur gear. So far I haven't had a crucial failure on the XVD's, bit have had a couple of bent pins. I have since replaced the pins with drill bit shafts.
Are the pin just standard that come with?
What size drill bit did you use?
On my super bully, I drilled the hole larger and used 1/8" drill bits. They held up to 8" tall rovers. Might work on these too."thumbsup"
Maybe Piano Wire?
Just read your build list and HOLY S%*T lol lol, gonna need to start sending pm's out haha.
