Cant the "wraith" be made into a capable scale crawler with say a 35t or 55t set-up?
Yes, it all depends on your setup. I wouldn't suggest a 55 turn motor to anyone though. A capable crawler still needs to have wheel speed. A 35 turn motor is as slow a motor as I would run in a crawler like this.
I have another Wraith on it's way to me already. That Wraith will be built as a scale crawler, rather than the speed focus this one has.
After posting that I was wondering if a 55t might be a bit much, thanks for the heads up. I'm new to the scale/crawler side of r/c so I'm still learning stuff. I'll be watching for the scale crawler build.
Found it, I'm not running brushless but a high turn motor so they should be perfect for my truck. I've had good luck with the stock shafts, just want something that rotates a little free-er.The MIP's or the stockers? The MIP's are doing well, the stockers weren't holding up to the brushless. Look at the previous pages for the stock driveshaft info.
I'll be using one of these motors, most likely the 16 turn (about equivalent to a low 30's turn typical brushed motor).
http://holmeshobbies.com/product.php?productid=420&cat=17&page=1
They have good low speed control and nice top end.
What do you figure you'll use for an ESC? 3S?
it doesnt matter whos behind what trend and where, this is a sweet truck. cool man. "thumbsup"
I'll likely buy a BRXL Waterproof from Holmes as well. Yes 3s 1800's will likely go in there.
At least I now know I'm heading in the right direction with mine when It gets here. I have both the br-xl and the 16T on the way. Only did is I have 2200 3s. Thanks for all the great insight Harley!
Do you think the stock shafts will hold up better with that set up than your brushless speed demon rig did?
With a minimal amount exposed there is no area to twist the male shaft.
Sounds about right. :ror:
Mine will be here Thursday, I can't wait! :twisted:
Here is a picture of the links that are on the way from Chaotic Crawlers. Can't wait to get these on. These will make a great fix for the wobbly stockers.
Nice, it'll be fun to have a few running around locally. You going to make it to the comp this weekend?
Are those links for the wraith? They are ti ?
