Dasco's xr10 build
Can't say it enough man, that thing looks sick. Great work on tidying up the wiring!! How's she running?
Runs like a champ..hands down best crawler I've owned..the motors really woke this chassis up and smoothed the low end out as well..thank you for the kind words Nasty it really makes me want to push harder...here is the undisclosed new rtr weight...shooting for under 4lbs
Sent from my HTC One M9 using Tapatalk
Bro... you are sooo close!!! You're gonna have to do zero carbs and hit the sauna to burn that lil bit off!! Haha!! Where do you plan on shaving the weight from?
Have a few more tricks up my sleeve [emoji326] ...the front gears are still solid and the upper links are gonna get switched from 3/16 to 1/8..should do the trick...I can also remove some weight from my Dlux knuckles once I've done that and still have good balance [emoji41] that's the plan anyway....hope it works!
What are you using to make your 1/8th links from, al, ss or ti that is very thin?
I'll be using grade 5 1/8 ti from mac master car...it's what I run now on my sporty and it should be strong enough..if not I'll report it to you guys, I'm pretty sure it will be tho as my sporty is a heavy weight ATM..lol
yea no doubt you can do under 4 theres so many little things that can cut weight on that rig did you try and take out every other screw in the wheel haha like i said plenty of ways but love the rig man i hopefully just got another fxr and gonna try and smash them ended up being cheaper but looks good and i could tell that green grass looked funny lol
top notch..and on the wheels it takes the ones that are left to hold them together. Thanks again dude[emoji12] I'll have a drill press very soon...then it's Swiss cheese time....heheheh
I'm so excited!!!! my new CreeperBob titanium axles for the rear will be out for delivery tomorrow!!!..does anyone know or have a weight comparison between the ti and stockers...if not there will be one soon..:mrgreen:
OK ladies and gentlemen..I received the CreeperBob ti axles in the mail today and did a quick check on the weight...a fair amount lighter than stock and thicker still!!! Here's what I'm at Rtr now
And some weight differences between the two
Stock
Ti
Right ...I'm gonna put speed holes in my front gears tomorrow..should put me there..also going to 14 gauge wire with the sidewinder's and no bullets...if that don't do it I'm filling the tires with helium..hahahahhaha
your so close man haha i know you'll get under 4 now no doubt i didn't realize how much those shafts made a difference in weight and to think they are stronger overall if i had the money my r10 would float on air lol
Thanks dude...I still need to get better at driving it. I spend so much time working on it and staring..lol...wish the rocks were closer than they are...I made a test course in my back yard but it became very clear that it need the side of a mountain to really test it ..not a few truck loads of rocks I can lift..lol
So I'm finally in the 3lb club guys..lol...just barely tho..still a few more things to do . Just thought I'd share. This is the new RTR weight with the smashed sidewinders and 14g wire!!!
