lonewolf8o
I see a couple of guys running carbon fiber upper links. What size diameter and do you glue the rod ends on?
Sent from my S7 using Tapatalk
I don't want to bother him yet, since I'm not sure i want to go that route. I'm assuming he makes them? Interested in getting info on how there made and the benefits. I'm assuming ones light weight and the other is running a thinner link for more clearance around other parts. Other reasons?Pm Nerby 149
Weights all I see, theyre just as thick as the Ti uppers I run so Id say 3/16 OD.
I had some on the front of my shafty last season, never had a problem or seen anyone break any. If you're counting grams I think they're worth it. I personally like the option of bending a Ti link vs snapping a graphite one if I get a little jammed up.
From this figure I figured the bottom one was 3/16 and the top one thinner?
Edit to add: Didn't notice till now in that photo, but does he pin them to the rod ends?
Moved my rear lower shocks outwards. Going to test it today. Was thinking of doing the front but looks like I'll have interference with the tires went turning. The people that have moved them outwards, did you move the fronts outwards too? Will I get the benefits of only doing the rear?
For the reasons you and Stuck mentioned. I feel I won't learn what I like as far as handling if I don't try it to compare, also to see how the truck responds to different setups.What's your reason on out boarding the shocks? I know some general reasons behind it(TT, stability), curious in this particular case. Thx.
Thanks for the info. I'm not sure if I saw your build thread, I have four others bookmarked but don't believe I saw yours. Do you have a link?I moved them out on the front and back. The little bit of rubbing on the shock wont hurt or take away any steering. IMO this adds stability to the truck and gives the shock a smoother suspension travel. Don't know if you have checked out my build thread but it has some good info on setting up this chassis
My front lowers are inboard of the mounts and the shocks are in the mount on the same screw. My rear shocks are out boarded and the links are in the mount using the same screw. With so much steering I had to inboard the front lowers or add massive spacers to clear the tires.
