Foxracer11
Well then might have to pick up a set and get rid of the fxr
The fxr's are what I'm running..seem to do well but I'm not sure they are as light as the BR mini's...I also have some sidewinder micros that are very light..but I'm not sure they will handle what I may throw at them...Well then might have to pick up a set and get rid of the fxr
Sent from my HTC One M9 using Tapatalk
Thx for the insight Robbob...I will go ahead and calibrate and smash em to switch out for Sunday[emoji13] I really like the foot print on the cc sw's better between the linksI ran Sidewinders for 2 seasons on 4S hammering on some strong Brood Vapors ....... never had a problem.
I figured it may help to keep em cooler if I put the FET's facing out...may try it if they don't get to hot...what are your temps like? And what motor setup and pinion do you run tapped-out?
Also smashed the castle micros I had kicking around..gonna try them soon!!
Thank you Sir...I have had quite a bit of time on the soldering iron over the past few years. Building flight controllers and stuff that makes you want to curse and throw things in the garage has finally paid off[emoji12] I want to switch my connectors to a smaller lighter option...are micro deans the preferred connector?Clean job "thumbsup"
Thank you for the complement fox....yes I did the smash on the tekin and fxr's...800 or 850 would work but the one in the pic I posted is a 450mah sticky for comping if I ever do [emoji12]..love the build dasco keep it going and was looking at the link did you do those yourself or purchase and was looking at either buying micros or running br mini smashed but don't have money at the moment but let me know how things are going my xr is about to get an upgrade of chassis esc and battery and looked at those but was going to go with the 850 or 800 mah can't remember anyways build is solid man looks awesome!
