Crawllife
Fifth dimension
I really don't like the look of the drag link being pointed down and away from the arc of servo travel. It is just bad geometry that will result in weaker steering the farther it turns. Ideally, the drag link should remain level through servo rotation, or at least go upward from horn to steering arm. That's one of the reason 86jeep steering setup a on Bergs are considered the best layout as the drag link and tie rod travel on the same arc as the horn and knuckle. Although my setup looks wonky, at full lock in either direction, the rod ends of my drag link are totally level horizontally.
So in the last pic I posted, with the drag being close to parallel, that's still way off? I have a 1.8 drag getting made for a bit more clearance. Behind the horn for approach is still my goal. I'm learning a lot here dude. Thanks.
