Thanks for the reply hnoroian I'll probably try pulling the wheels apart soon.
I pulled 2 of the 4 tungsten slugs out of the driver side knuckle and moved 2 of those to the passenger side rear. While I was playing around with that I was reminded that the side to side weights on the SkyRC scales are calculated wrong. The left (bias/balance) percentages are based on the Front right + the rear left and vice versa for the other side. So to get the reading I want I had to swap the rear scales side to side.
I sucked the suspension all the way down while weighing it as it would read different every time I shifted it around, even after that it still shifted around.
As for how I'll add the slug to the rear axle I'll probably design and 3D print some mounts.
