Man, if only somebody figured out how to make the rear under drive even more.... Oh wait... its been done.![]()
im taking it even a step further Erik "thumbsup"
its not in the gears either.
On another note, do you think it is too late to ask Axial to release the cutting brake?
And yes, when it comes down to it, Chris is winning again, and that means 5D is kicking everyone's ass.
I think the way to solve the mystery is to have Erik get back into the sporty class..."thumbsup"
what im about to test out after I give a few measurements to him so he can machine some stuffs.. might make him want to get his pinky in it.
1 way bearings with 12mm hex's do exist.
Just remembered something a lot of us do also, blip throttle induced steering to make even tighter turns. Another thing I noticed between the two is again the non 8* would just hop forward where the 8* hops into the turn...
Least amount of traction to most amount of traction:
8*, zero scrub, zero caster, toe out
8*, zero scrub, zero caster, neutral toe
8*, zero scrub, zero caster, toe in
8*, minor scrub, zero caster, toe out
8*, minor scrub, zero caster, neutral toe
8*, minor scrub, zero caster, toe in
8*, minor scrub, 10* caster, toe out
8*, minor scrub, 10* caster, neutral toe
8*, minor scrub, 10* caster, toe in
8*, decent scrub, 10* caster, toe out
8*, decent scrub, 10* caster, neutral toe
8*, decent scrub, 10* caster, toe in
8*, decent scrub, 20* caster, toe out
8*, decent scrub, 20* caster, neutral toe
8*, decent scrub, 20* caster, toe in
NON 8*, zero scrub, zero caster, toe out
NON 8*, zero scrub, zero caster, neutral toe
NON 8*, zero scrub, zero caster, toe in
NON 8*, minor scrub, zero caster, toe out
NON 8*, minor scrub, zero caster, neutral toe
NON 8*, minor scrub, zero caster, toe in
NON 8*, minor scrub, 10* caster, toe out
NON 8*, minor scrub, 10* caster, neutral toe
NON 8*, minor scrub, 10* caster, toe in
NON 8*, decent scrub, 10* caster, toe out
NON 8*, decent scrub, 10* caster, neutral toe
NON 8*, decent scrub, 10* caster, toe in
NON 8*, decent scrub, 20* caster, toe out
NON 8*, decent scrub, 20* caster, neutral toe
NON 8*, decent scrub, 20* caster, toe in
I am just shooting from the hip on those thoughts, might be right on, may be way off. Either way, it would be cool to figure out and then you could take it a step at a time until you found the spot where its a good compromise between steering and ability. I would be super curious to see if the least amount of push "NON 8*, zero scrub, zero caster, toe out" from a non 8* would be too much still. Seems if you went off the assumptions that I have charted above, what you have now would just be one step below "non 8*, zero scrub, 0 caster, toe out".
A lot of copy/paste. LOL. I forgot all the types of ackerman too!Phew. that is some typing!
I think we should also remember that the non 8* knuckle setup loads the front outside tire once your turn, whereas the 8* setup keeps the axle relatively level to the ground.
Hi,
I appreciate this discussion, become too rare…
Here some 3D diagrams, to illustrate the effects of the various adjustments of the front axle. The wheels are steering with 70°.
NON 8*, decent scrub, 0* caster, neutral toe
That is a great idea. I wonder how long the bearings will last though with the amount of grip, torque and bind modern day comp crawlers experience.
Most of the one way bearing experience I have is with 4wd drifters and 1-10 buggies. neither of which experienced none of those factors. The other being they all still had open limited slip diffs.
Other issue I see will be that the rear axle will have no drag brake or power under reverese throttle.
I would like to see a steering battle. how do we set up our front axles the right way????? "thumbsup"
