Castor is the same on both, 20*, and toe is the same also. I'll get a pic later after work. On a pro I like non 8* (probably cause of the dig if needed) but just wasn't ever satisfied with it on the sporty.
Man, I dont know about you guys but its starting to feel overwhelming with all the things to think about in sportsman and their steering. Can you guys just install dig in these cars and call it good?
I feel a bit out of my realm because I dont drive sporty and dont have much experience at all with them.
I know I felt steering was very important with these cars but I think the question coming up in this thread and what Chris is stating (at least for himself) is that steering is more important than traction and other benefits? Seems a bit wild but I guess I can see it.
Non
I had to play a lot with the arms I have on my sporty to find equal throw and ran into similar problems. I found running shorter arms, think like Losi knuckles vs Axial with the stock ears, I got more steering then running the longer racing arms.
Quicker steering - stronger steering - less servo throw needed, actually turned epa's down ..... if that makes sense.
I dont think this should be trues unless you didnt/couldnt adjust the rest of your steering?
In my findings, if youre arm on your knuckles is 1", your servo should have about a 1" long arm to get full throw. On something like the Losi or B2, the arm on the knuckle is much shorter so you can run a shorter servo arm.
Basically you should be able to get the same throw/angle but the steering arm needs to compliment the knuckle arm.
So, I think the steering, all things being equal should have the same strength, same speed and same throw?
The only thing I really didnt like about short knuckle arms is that you need to have a short servo horn and it seems like things like to cam over much quicker that way where as a longer servo horn and longer knuckle arm seem to not want to cam over on themselves making it an easier system to setup.
Different axles then me but Im wondering if you were to take and move your left front tie rod in towards the king pin ... you think you would actually get more throw into that lf tire?
Have to bend the tie rods to clear the pumpkin but you could get more angle to the inside tire with out sacrificing the outside. I don't have experience though with AR60s so I cant say Ive done anything to them.
That setup just was what it was. I was trying to get both tires to get full throw and I did. The outer was scrubbing the diff cover and I dont think you can see it in that pic but the inner tire was rubbing the link mount. I even trimmed down the link mount but didnt eliminate the entire side of that mount because I insisted on double sheer.
Also why we saw/felt a sharper steering in the XR over traditional setups of the past.
True(er) zero ackerman because the steering was bta. ;-)
I have always wondered about this quote. I have heard it from many, many people and usually when I question, there is never anything but a blank stare. Maybe its because I am missing something simple? LOL.
I heard this pretty much as soon as the XR came out. "I went to the XR because it gets so much better steering that then Berg". I would hear that all the time. This is before almost anybody ran modified universals so I know their universals were only good for the same turning degree as the Berg, about 58*.
Maybe it just felt better or actually was better because like you were saying, the ackerman is a bit more true? Or, maybe its because the 8* brings less scrub and its able to turn with less force?
I feel we need some serious testing on 2.2s and 2.2P.
In my "ideal" description, ......
IMO, it might be worth hashing it out but seems there are bigger fish to fry at the moment.
I imagine having your or my "ideal" setup but making the tires so they turn 90*. What I am wondering now is if there is a point of diminishing returns? We are all shooting for more turning angle but should we? What if you had either of our "ideal" setups but found out that since the rear is a huge determining factor that 60* of steering will actually out turn 90* just because of the lack of push?
If you are on the same page as me above, now there are so many other things to be curious about.
I think you could almost chart out setups that allow the least amount of push/traction all the way up to the top end that makes the most amount of push/traction. Just for fun, lets say the bottom of that list would be 8*, no scrub, no caster and then the top would be non 8*, lots of scrub, lots of caster.
Now, I think you should tune each item individually until youre where you want to be. The bottom of the list (8*, no caster, no scrub) might get you the best turning radius but at what cost? Maybe now you cant make a climb or a side hill. Thats going to be a tough one to figure out.
Another example is that Chris might be able to choose which attributes he likes the best and tune from there? Say he likes the benefits of caster more than anything else so, keep the caster at 20*, go 8* and then scrub might be what it is since we are forced into that more than anything. OR another option might be that he likes non 8* so much that he wants to keep those traits but reduce the caster to 0*. Is 0* caster and non 8* going to be similar to 8* and 20* caster? Maybe? Now he also eliminated some push but can keep some of the good traits that non 8* offers. Much to think about and test.
which ever tire has the most traction has the most say in direction of travel.
I think this is the problem. I think the rear tires have the most traction and say in travel when youre tires are almost parallel to the housing.
After having another 5 hours on the road thinking on this subject I'm pretty sure dlux is right. And wrong. :lol:
Good pic.
