NCD High Performance Carbon Fiber 2.2 Shafty/Sportsman Chassis
Looks great. What is the ground clearance at the high point of the rear links in that side veiw? I see that mounting the rear shocks in the lower chassis holes would provide more rear clearance if needed. Thanks
Clearance at the highest point is 85mm with the car compressed under its own weight. Max clearance is 92mm.
The rear lowers now follow the driveshaft.
I will have a high clearance option available any day now that increases clearance towards the rear. This may make your dirveshaft vulnerable though, depending on your amount of clocking.
My personal preference for front skid plate height on a shafty is around 70mm. You really dont want to take it much higher or you sacrifice sidehilling performance too much.
Thanks for the info Tomy, im anxious to see the higher clearance options(rear lower links?)
Here you go:
The chassis is looking better and better Tomi..
Those links have even a better clearance then my Ti ones... SO i need them for the supercrawl ;)
The more I look at this thread the more I think this will be my chassis I choose to build.
Tomy how much will a chassis with these new high clearance lower links , plus upper links and servo mount cost me posted to Australia.
Also how much extra is the cab for the top? Not sure if I want the cab yet tho.
Looking for the same. To Prescott Arizona USA
Thanks
Thanks
Base chassis + delrin lower links are 70 euros shipped.
Bodiless chassis + links are 95 euros shipped.
Add 15 euros for a set of front and rear link plates of your choice.
Thanks for your interest!
Tomi
Hay tomi first got to say your chassis works orsome.Can u tell me how much to get the new high clearance lower links plus a CF ax10 motor sent to australia.
Thanks
Steve
Steve im not sure if the AX plate being sold yet. Mine are on route and Douwe and Everett only just got theirs. We have to test in use geneally, but Tomi may be able to help you out.
Ben
Thanks
Steve
You had stated that there were options for front and rear link plates. Is there a link to some pics? I'm going to buy this chassis as soon as I get the options I want figured out
He doesn't have a link but just PM Tomy and he'll give you a price for them ;-)
Look at my thread and Ronalds as i have a different 4 link front plate to him .
Sent from my GT-I9300 using Tapatalk 2
