NCD High Performance Carbon Fiber 2.2 Shafty/Sportsman Chassis
When will the next batch be ready and I take it euros is the same as it is here in the states right.
Euros is different... Use google to figure it out ;-) Just type in Euros to USD in google click search and than you can convert it... 65 euros is $88.69 "thumbsup"
I am taking new orders on the AX10 Sudu version.
Shipping will be 1-2 weeks after I have recieved your payment.
Tomi
I got my chassis on Wednesday and quickly mocked it up and will be ordering someparts to finish it up this weekend. Can't wait to get this on the rocks"thumbsup"
thanx Tomy"thumbsup""thumbsup" stoked to get home and bust open the bags. Drail
Hello! Im interested in this chassis. Is there any plans to offer ti links in the future?
Right now I dont have sufficient time resources to make Ti links. With the equipment I have available it takes me a lot of time.
But if anyone wants Ti links and can find someone to make them for him I am more than willing to provide dimensions.
Thanks!
Tomi
I have done a few updates to the chassis.
The delrin lower links have been re designed for better clearance around the shocks and driveshafts. These links also have a much tighter and secure fit for the set screw. You are not likely ever going to strip the set screw threads.
If you are using the first version delrin lower links, I recommend you update your links to the v2 ones. PM me with your address and I will send you a set free of charge.
New Front Links
New Rear Links
I also re did the skid plate. This change has no real effect on performance, it is more of a cosmetic update. The skid plate is now designed so that it runs over the cf chassis side plates.
This update is not a direct bolt on on the early chassis plates. It will fit, however, if you slightly trim the skid plate mounting holes.
From now on all chassis come with the updated skid plate.
I can do that. :)
Based off the current rear lower link design it would be very easy to do an "extra high clearance version" for anyone wanting that.
I wont this even more every time I look at it.
just waiting for the bodiless setup to come out before I pull the trigger on one.
