Let's go back in time for a bit. Before messing with the tars, I built the shocks. Painting is by far my least favorite part of a build, but shocks are probably second. In this case, the shocks didn't fight me too much.
I found it odd that the manual didn't suggest a starting oil weight. Yes, this is a personal preference, but it would have been nice to see a recommendation on oil weight especially for newbies. The oil level dimension was nice, but that is tough to measure so you have to eyeball it. My eyeballs are out of calibration so let's see how this goes.
I liked the drawing of the rag. It looks like a ghost to me. :lmao:
I ordered 70 weight upon seeing Harley's or Ty's build. I forget which. They used 60wt and I wanted to make a more drastic change from my typical 35wt to see if I noticed a difference. Then, before building the shocks, I did another search on the FB group and saw that 40wt in the front and 70wt in the rear was preferred by Dan and others. I did not have 40wt on hand so I will be trying 35wt in the front and 70wt in the rear.
The shocks are really good looking pieces. The dark grey anodizing almost looks like black chrome. I like it. Of course, I'll be using green slime as well.
Here you can see a closeup of the "black chrome" look on the caps. You will also see that the preload adjuster has a lock nut. Another awesome feature. I do not believe I've ever seen this on any other RC shocks that I've built so this is really cool to see.
I wanted to disassembled the shocks completely so I could put green slime on the X-rings. X-rings are a very nice touch instead of o-rings.
Step one was removing the cap. I couldn't get these off by hand. Whatever kid in Asia assembled these shocks either had superhero strength or they used tools to lock them down as tight as they could. I had to use shock pliers on the shock body and then an MIP hex driver though the hole in the cap to get them loose. :shock:
Upon removing the bottom cap I found that the bottom of the shock body had flat spots for a wrench. I tried removing one and found that it would come loose no problem, but then it would reach a hard stop. Using a shock pliers to hold the body and full-size adjustable on the bottom it wouldn't turn at a certain point. I was using more force than I thought would be necessary so I stopped rather than risking damage to the shock. The bottoms on the other three shocks were rock solid and they wouldn't budge with a decent amount of force so I threw up the white flag and decided to remove the shock shaft out the top.
The spring cup is captured which is awesome. If you've ever been on the trail and suddenly got gangster lean due to losing a spring cup you know how valuable this feature really is.
The screw not only ensures the shock cup won't come off of the shaft, but it also runs through the shock end and locks the spring cup into place. Nice.
Filling and bleeding these shocks wasn't too bad. The first three went fairly easily. The last one fought me, as does usually happen with the last of anything, but I persisted until the rebound was close to the others. The shocks feel good with a smooth and consistent stroke.
The lower shock cap doesn't seem to want to stay tight even if you install it with tools. I'm anxious to see if this becomes an issue. Maybe I should have installed Teflon tape here, but I did not. I've read a fair amount of people having leaking Incision shocks and I'm guessing this will be the problem spot on my particular shocks.
The only place you will find plastic balls in this kit, thankfully, is in the upper shock mount. You don't want a metal hollow ball riding inside of the aluminum top so plastic is necessary here.
This mold is filled right on the large diameter which isn't something you'd typically want since it is the pivot point. But here it's not an issue at all.
