I watched ur videos a few pages back..
Two suggestions if I may
Lay your shocks back one hole maybe...
And BOIL your rear torsion plates... It'll soften it up n flex nice n smooth!
Looks good tho otherwise!
I never did see any measurements on ur xr mod tho for housing
And axle lengths..
Yeah, I have to get some updated video..
At the time of the video it was new an stiffer then now
It was only 7.5" long, wheel base.
No knuckle weight or lockout weight
The shocks are back in a hole in the chassis, not in a pre planned shock hole.. they were full sized pro shocks limited 11mm. lol, it was a mess an on the rocks!
Since then all the mods have taken place an loosened up some..
I'll get more video once I get It out an the front axle figured out.
At this point the xr axle pieces are 39.5mm or 1.55" long.. I'm not sure bout the axle shafts but I cut to fit. I cut a good inch plus off of them.. when I get final finish, ill post..
Side note: t3rry made a diy video in his thread, then changed a bunch of it. The main part of smoothing the mrc axle housing an drilling the xr axle housing is the most important part. The rest is up to you, track width, ur wheel offset, etc.. I started with the widest track width possible.. making shorter is always the easier, cheaper option..
