JonU
He isn't waiting fir the stock tires to wear out maybe post#103 will help you
lol, i guess i'm blind. thanks for pointing it out
Both stock driveshafts finally ate it. I was impressed at what they took for abuse. I shot some video and believe I got a shot of the front one breaking if it wasn't too dark.
These shafts are damn smooth though. It would be nice to have some metal shafts to go with the nice CVD joints.
Yeah it needs a BEC with a 3s is needed 100%. I was shutting mine down without it.
Well, I'll go ahead and say you do drive your cars hard... That is one we haven't seen before...
It is more than likely the 3s combined with wedging the tires into a crack, something will eventually give... But, how do they compare to the old driveshaft style? You could loosen your slipper a little and that would prevent any breakage... Although, I know that's not your style...
Does the stock esc have a auto lipo cut off to know it has a three cell?
Wait so are you TRYING to destroy it? :shock:"thumbsup"
Is it necessary to stay on throttle while jumping in order to make it fly level? Is that due to the drag brake? Do you think that the shafts would stand up to the normal crawling stresses?
i got a mini losi pro to see if i like the crawling side of this....but seeing the video.....yes the wraith is the truck i want....just need a better body
Looks like she handles pretty damn good at speed.."thumbsup"
is there a place to mount a winch ?
I will not be drilling out the output, I think that is a bad idea. I may however turn down a long 4mm set screw on the lathe to keep the cross pin style as I am a HUGE fan of that design. Wish the upgraded pinion gears were drilled for that as well.
You've got patience if you're going to turn down a 4mm set screw on the lathe :mrgreen: Sounds like the best solution though.
I agree, wish the upgraded pinion gears had the through hole as well. In the Wraith manual, Axial only lists the currently available upgrade r&p sets. I wonder if there's plans to offer them in a "Wraith" version with the hole?
