Foxracer11
wow thats nuts man congrats i wonder what weight difference there is between the micros and the br mini's
Thanks brother!!! I would say that the BR MINI's are lighter. I will get a set one day and compare. My friend is getting ready to do a build. I will be helping him so I may be able to weigh his. The only problem is they will be smashed so it will be hard to compare the weights of each escwow thats nuts man congrats i wonder what weight difference there is between the micros and the br mini's
Looking forward to the build thread foxthats a big difference I'm ready to start my rebuild of my xr10 after i get the rest of the parts i need like the smashed br mini's and new bearing and a few other things but yea i figured they were gonna be lighter still perform just fine though
Thank you Adam...you Snap and Barry helped me out tremendously. I have a few more tricks up my sleeve..lol. stay tuned!!!This thing has came a long way from what you started with, great job with the thread lots of good stuff in here for guys looking to do same.
"GOD SPEED"
Look what I got...10 points for the person that can tell me what they are and who makes them
Sent from my HTC One M9 using Tapatalk
Lite weight hot racing gear set?
Lol...too late...j/k...if you put the male or female on when you solder them it acts like a heat sink and works good to help keep the slots true..here's a little weight comparisonHaha!! Don't do what I did!!
Thx bromang...didn't think of adding a little extra wire to dissipate the heat..that's a top tip[emoji41] these deans/t plugs will strait get wonky without doing this though....Good info! I have a male and a female with a inch or 2, of wire soldered to them and the coating peeled off, sitting with my solder iron. Haven't had a deformed plug yet. Not from soldering anyways! Lol..
Rigs coming along pretty nicely, mang!
Not sure yet brother ...I'll be testing tomorrow and let y'all k of my findings..they are at hobbyking if you want to check into themso its not a true deans plug its a mini deans does the amp stay the same or does anything change is what I'm asking because i have normal deans on mine
