Yep!
Here ya go:
It's attached at the shock hoop screw holes. I just swapped the stock flat heads out for buttonheads a couple mm longer. The wells fit this body so tight I almost don't need body pins.
Fitting tips:
DON'T PAINT until it's trimmed and do one corner at a time with the BODY MOUNTED. Unscrew the top screw from the shock, cut the container in half, and stuff it up into the wheel well location. Slide it back and forth and up and down until you find a good fit that suits the body and wheel location. Use a sharpie to mark the location of both screws at the bottom of the shock hoop. Drill the holes and mount it, then you can trace along the frame rail and mark where you want to cut the back edge so it doesn't show under your body/bumper. You might have to cut a big hole at the top to clear the shock, or you might just need one hole to pass the screw through.
I first painted with Tamiya paint for lexan, but it didn't bond with the plastic. Krylon Fusion seems to be working better.
