damn, where are you scoring all the Moab XL's? I sold a couple sets I'm thinking I should of held on to.
Thank you "thumbsup"
Mean yet polite :twisted:.
He's that way. I just finished a set of blockes with trencher side walls.
which CA are you using?
BSI Insta cure 1-3 sec., BSI insta cure + 5-15 sec. and BSI IC-2000
Ryan I both use the 5-15, and the IC-2000. You might try washing the sidewalls in Simple Green then letting dry. Hopefully by doing that the tires will become a little bit tacky and softer"thumbsup"
No shit, I got a set off him too. Even came with three in the plastic and one not.
Bob, dont glue them all the way. I only use 4 spots on each side....they are easy to get off that way. Oh, and use some cheap crappy CA glue....not the good stuff!
Try thicker CA..."thumbsup"Yeah I tried that, but you know how a little bit RUNS a long ways :evil:.
Yep...the 4 spots and thicker CA works great. I've only had one section of bead blow out once before...was a pretty good drop that caused it, but I've wadded them up quite a few times since then with no issues. I haven't tried removing them yet, but I wouldn't imagine it would be too hard.
