Man I absolutely love this thing. Well executed.
Thank you, for winging it a bit I'm super pleased with the results
It looks beautiful sitting out there on the rocks! Great color choice!"thumbsup"
It's been fun following along with the build and seeing it all come together! Once again, great job on the metal work! That cage looks awesome!
Thank you I appreciate that "thumbsup"
I tend to stall when I'm close to finishing off a project trying to extend the fun of the build I guess :lmao:
Thats where the cut off switch came into play. I had fun designing the geared design thats less than ideal in terms of size and complexity. I kind of pushed through with multiple iterations just to get it working and then I stood back and realized it wasnt gonna fit and i'd made it far too big.
Enough rambling here's some pics after I finished the wiring including a simplified cut off switch.
For the switch I went back to the first design moving the fulcrum closer to the switch for more leverage. I also built in some slop to the mechanism so the actual switch lever moves the distance it should.
the black part is the switch
It sticks up above the hood just a bit so I can toggle it easily. I used a long screw for the nearby hood mount which serves as the mount point for the switch, bent up some lexan and painted it silver for the dash panel.
I used some mesh wrap to clean up the wiring. It was a bit of a pain getting the right lengths and heatshrink in the right places as I built the harness. Its nicer but still a bit of a mess due to the less than simple setup (2 servos w/ direct power and light bar with inline switch)
I guess I never showed the battery tray after I installed it. Its not parallel with the rig but at an angle. I thought this would center the weight better.
you can pick up the angle from below a bit better
Speaking of weight, final weigh in with the 1400 mah 3s packs was 5.83 lbs
These seem like a nice pack for a light-ish weight build, small but with some capacity. Though I didnt like how long the wires were so I shortened them by 2 1/2" or so.
Today I spent a few hours doing the final setup, centering servos, threadlocking driveshaft pins & servo screws then the actual radio programing. I struggled with the 4 wheel steering setup for a bit and finally found a video that went over things that arent in the manual (or at least in the spot that would make sense). If you have a Spektrum DX5R C or Pro this video explains the drive mode settings you need to change to get the 4 wheel steering working:
https://www.youtube.com/watch?v=T4DEuirstUM&feature=youtu.be
with that I got back on the right track. Getting the order of the drive modes to match what the rig was actually doing as I changed steering modes was...uh interesting. I tried reordering the drive modes and from the 4 wheel steering setup but as one end shifted so did the other.
I finally got them in the switching order I liked (its 4 positions). All the way up is normal front wheel steering, one click down is 4 wheel steering, next click is rear wheel steer then crab steer. I found the way to get things to match on screen with what the rig was doing was to just rename the drive modes since shuffling the order didn't work.
The 8mm (wheel) nuts for the VP axle stub need a washer which I wanted to eliminate. I got some flanged nylocks which didn't fit so I whittled them down with a file, cordless drill and M4 bolt with the head cut off.
I took it out for a short run, it was rainy and I didn't want to push it on the first run with such an open rig. From what I saw so far its behaving great, super planted and I dont think I even dragged the belly yet.
I'm just learning 4 wheel steering and how to drive with it but I think I'm starting to get the hang of it. I ended up using it so much I had to tell myself to drive a few lines with normal steering just to feel that out.
Moved my 3d printer out of my scale garage for a little shoot while its still shiny.
