I've got a few of those dlux portal transmissions, they are killer! Like you I went from a 2.low to the dlux unit.
I decided to keep the 2.low and use the Dlux Portal tranny in my next build. Looks like I'll need to wait on Capra axles shafts to get re-stocked though. BTW what motor did you use with your Dlux portal tranny? I'm assuming something on the slow side would be best like 1000-1800KV.
Looking good "thumbsup"
Thanks!
I was able to put a few bends in the ESC mount to get the clearance I needed. I cut one end loose to make up for this piece pulling the sides together and then filled the gap with my mig :mrgreen:
I thought I was going to have to move it up much higher and then space the ESC down accordingly but this works much better.
I also did a bit of work to the front servo and servo mount. before I can get to full compression up front the servo horn hits the cage, this limits travel by 5-6mm.
I filed down the VP servo mount around 2mm
Then to get the servo to actually sit lower I extended the mount points on the servo. I 3D printed a jig that uses some metal sleeves so I could use a drill bit without destroying the jig. I also found a lower profile servo horn but when I tried to pull off the VP horn I got the sense I was about to strip out the screw holding it and decided to just live with it.
I got a little bit of crawling in yesterday and I'd forgotten how much I enjoy this rig and 4WS. Unfortunately the rocks at the beach had a ton of wet sand washed up on them so the typical grip was not there. The tires got all sandy which I usually try to avoid but there was no avoiding it yesterday.
