Rockatanski
Ordered mine - thanks to Tomy!
Thanks, John!
A little something in the works for all Sudu One owners.
This is a custom tranny specifically designed for the Sudu One chassis using RC4WD R2 gears and the optional long output shaft (short shaft in the pics). Weight will land at 20-25g less than stock. This should fit all Sudu One versions but will require a new skidplate.
I would be happy to offer 3 interested Sudu drivers the transmission housing, hardware and skid plate at no cost in return for drive time and test reports. Test drivers will have to purchase the gears from RC4WD. If you are interested to test out the tranny and able to do it within the next month or so, please send me a PM.
Thanks!
Tomi
Thanks, John!
Thanks!
Tomi
Hi Tomy,
Does a R2 tranny (without dig) would fit into the bodyless version ?
(sorry for my bad english)
Truespace
What's the dimensions in the gearbox as a standalone unit?
Just trying to find out what way to go for my current project.
Your thoughts on max/min pinion gear? Overall ratio from motor shaft to output shaft? Obviously depends on pinion size...so just pick one.
Hi tomi would you recommend aluminum screw on the gearbox or better to stay with the steel screws
Cheers Rino
Sent from my GT-I9505 using Tapatalk
