Some people say I'm "extra". I say I'm Ultra! :lmao:
I was sure that I was going to buy a Pro kit after building my Limited. I'm glad I waited because, unbeknownst to us, Vanquish had the Ultra up their sleeve. I was torn between the Pro and the Ultra, but I ultimately decided on the Ultra because it's most dissimilar to the Limited. With the Ultra I'll get the VFD transmission and portal axles which I think will be of big benefit here. I'm sure a Pro is also in my future and then I'll be able to compare all of the VS4-10 flavors, but that's in the future.
Another thing that swayed me towards the Ultra is that, while the portals raise axle clearance by 13mm, the 10mm shorter shocks make it so that the chassis and center of gravity are only 3mm higher than the Pro. I know I also have less articulation, but you win some and you lose some. I've never been in a situation where I've felt that a truck with 90-95mm shocks needed more articulation so I'm hoping, and assuming, the 10mm shorter shocks also won't be an issue.
Because I'm ass backwards, I ordered the 21% OD gears for the VFD transmission before I received the Ultra kit. It seems easy enough to remove the transmission, but I figured why not throw OD gears in there right away.
If I had waited for Harley's Ultra live build I may have went with the rear "underdrive" portal gears because it's a cheaper option and you get slightly more overdrive that way. Oh well. Impatience gets the best of me again.
![](/forums/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FfsCyGbLh.jpg&hash=cb6e2e1c2e4ec592e71407e014946633)
Just a week after preordering, my Ultra kit showed up on my porch! That's the way it should be. I hate when companies tease products with stupid, little photos and videos and then two months after the first photo you have the announcement of a disappointing vehicle. Just release the damn thing already!
I'm serial number A1812605. No idea what the code means.
![](/forums/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FbymGfFHh.jpg&hash=808f33aec31672573081a0b3fa7d80b6)
I was blown away when the shipping box had the price on the outside! :shock: This is dollar signs for package thieves! I'm lucky enough to live in an area where crime is very low, but if you aren't you may want to be home to receive this package!
The censored portion of the box is a code that gives me exclusive rights to 50% off all Vanquish products for life! :mrgreen:
OK, OK you called BS and I must admit it's just my address written in Sharpie, that I covered up. :lmao:
![](/forums/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FAipEm4lh.jpg&hash=b896136eee466570ed5de2a73378e6e2)
Inside of the Vanquish shipping box, we have the Ultra kit box. It's a very good looking box.
![](/forums/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F2BqlEBjh.jpg&hash=fdc9e3e14d9cbdfc5468db884cf5f1e3)
When I opened the box I was expecting a laser cut piece of foam on top organizing and highlighting the aluminum parts similar to what came in the Limited box. Sadly, that isn't the case here. The aluminum parts are bagged and thrown into the box with the rest of the stuff. I'm not a stickler on packaging though so no big loss here.
![](/forums/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FmsZxe5nh.jpg&hash=c37577e09632fc4107b3a5bd84e6fcde)
That's as far as I got on this build. I've been too busy playing with my Prusa 3D printer.
