Thanks, thanks, an thanks Ryan!
The CF turned out great! Now I think ill get some thin lexan to add a layer off the roof, I'm not in any hurry to scratch it all up!
The Bwd modlocks are a sweet look for any rig, there lite, thin at only .5" wide, an strong! I wasn't sure bout the foam support on the inside, but sure worked out surprisingly well today crawling around the rocks at the house.
Haha, des-Troy.. it will be Troy-built to keep it reliable an running strong!
On with it.. got out on the rocks for a couple 300mah 2s packs..
So far in "stock" form, no weight, no wheel wideners, crawls awesome for straight off the work bench!
The right amount of flex, I would like to even it out, a little less up front, make the torsion really work. Climbs good, could use a ud or od, mainly a tighter front end would do..
Found the lift point for the rear, tho it stayed planted with no problems. The torsion is very smooth an forgiving. It doesn't get funky or push back, very predictable so far.
Also found a wicked little side crawl that surprised me, after I get my rcbros servo mount ill gave my mini juice out an run the same lines an get a good comparison... The torsion holds solid on this crawl..
Had a couple roll overs, even side ways, it wants to rite itself easily. The servo guard took the rocks well, with minor rock rash showing after a number of roll overs..
I came in to put some weight on the rear, decided to hang lights to surprise the wife am it started raining.. again! So ill get some video up as soon as mother nature allows..
