Greetings John.
I purchased 3 of your 1300 3S Lipo packs (order ID#3245) on 3.19.09
the Triton is reading no battery when connected and the Blinky is reading it as a single cell...no initial 3 count of LED's when I plug in as on the other 2 packs.
I tried lowering the mAH setting on my charger, but it still detected no battery.
Suggestions?
Send it in, my addy is right above your post.
Any updates on your new ESC?
http://holmeshobbies.com/product.php?productid=274&cat=2&page=1
I'd buy 2 today if you had them.
A batch was produced last week, I am waiting for the final touches.
Sir,
Just wondering when will the Holmes Hobbies 25C 1300 mah Lipo, 3 cell, 11.1v, be available?
Thanks
Good question, I need to contact the factory on them. Should be ready very soon now, I have a few hundred packs on the way.
jrh, the to 10t cobalt works great, but....
did one comp (two courses) and heard a funny noise coming from crawler, upon further investigation i found that the armature is spinning inside of the end bearing on the wire side of the motor, at low and high rpm's it spins freely inside of the bearing, literally grinding on the innermost ring of the bearing, causing alot of heat buildup fast, i tried to lubricate and it hasnt helped....
in the comp the dx3s said it never got above 150*f...
what can i do to fix this? do i need to send to you? is the arm or the bearing at fault? smaller bearing? thanks for your time.
So there is play around the bearing? Sounds like the armature wasn't seated properly. I would push the opposite end with a wooden stick to see if it will seat, then tighten the endbell per my motor care thread at the top of this forum. If you cant figure it out just send it my way, addy about four posts up.
