Yeah, 3s is good. It just wears it out and you may want some advanced timing to stop premature brush and comm wear.
Upping the pinion would make it run hotter. The 3s lipo is why it runs hot.
jon. i have tried contacting u several times with no real answer to my question. i dont feel right asking this in the public portion of this forum but im hoping to get a straight forward answer.
i bought a few 45t torque masters a few months back. after only 4-5 packs i lost power in one. it turns out that the arm was bad (i can go into more details later on the problem if needed)
i emailed u a few time and was redirected to where i could buy a new arm on ur site. am i taking this as a loss? i used HH for its outstanding support so im hoping u can back ur product. this motor is in PERFECT condition with maybe 1 scratch on it.:|
JRH, will this work for an e-maxx basher for a titan 775 motor, and when will it be available ?
http://holmeshobbies.com/product.php?productid=274&cat=2&page=1
jrh, Funny, Because when i held the motor the bearing on the end would "let go" and the race would stop spinning with the shaft, especially when varrying the throttle thru the rpm range, i know im not crazy..... but if you say its ok i believe you. has it been shipped? what do i owe you? thanks.
I am interested in purchasing your ESC (Torque Master BR-XL) I need this by Saturday 8/1/2009. Please let me know ASAP if you can accommodate my request.
hay john i have a quick question. what is the difference between the crawlmaster, crawlmaster sport, and the revolver black? is there a difference in power or anything?
Just an easy question for now. I ordered a new armature for my 7t cobalt puller and i might have forgotten the orientation of the can/endbell when i pulled it apart, it was just along time ago.
Any tips for getting a good baseline of 0 timing? or where it 'should' be stock?
Thanks!
The crawlmaster series has a bit more power than the revolver. The Sport model has thicker laminations and is a bit less efficient. All three motors are discontinued while I develop a better one.
John got my motor cut...put on brand new brushes...and it still has a dead spot...it don't matter what I do...I advanced the timing and retarded it and it still has the same dead spot???
thoughts??
I know these don't last for ever...but dang these motors are only a few months old...:?
Sounds like you got a deep burn mark on it. You can send it my way and I can see what can be done to save it or replace it. A deeper cut may be needed.
I am going to see if there is anything that can be done to keep the comm burning from happening so fast. A design change may remedy the situation. I think it may be a combination of the low resistance wind, zero timing, laydown brushes, and maybe high voltage that is causing the fast wear.
ok...what your address?? I tried to look it up on your site but no go....
thanks for your help on this.8)
716 W. Sexton rd.
Columbia, MO 65203
>.< any idea when you will be putting out some new out runners?
Hey jrh I have 2 questions. First can the 10t puller handle more than 3s??
Also I cooked one of my 7t motors (let it get up to 300+ degrees ) it still works but it doesn't have the power it used to. Did I kill the magnets? Can it be fixed ???
Thanks, cole
hey John I have been moving and did not get a chance to ship my 35t with the dead spot out to you yet...
I just printed a USPS label and it's now ready to go!!
should I send both motors in?? my front 35t works ok still....but if you can rebuild or freshen it up I would rather just send both motors to you and get 2 fresh..:mrgreen:
let me know...maybe these two can ship BACK out with my custom 40T's I ordered a week or so ago???
thanks for your help and time on this
Mark
I just want your opinion on what I should get. I have a AX10 that will have a FX-R with a 55t motor, right now it has a Rooster. I want to run a 3s but I have no idea what to get. I will also need a charger, thanks for the help.
