Do you know what he cost might be on the VP CMS ?
I have run mine completely underwater for extended lengths of time without ever having an issue.
I would say BRXL.
I've been around crawling for a while and always refer to Harleys threads for
everything. Thanks for all the work and research you do, it takes out all the
guessing game. I'm doing a Wraith with my 7 year old son and even he wants
me to refer to"what ever Harley did" to make it work LOL And you totally saved my
4PKS from getting tossed off a cliff once or twice, so I just wanted to let you know
what an impact you have made in this sport and figured a "THANK YOU" was in order......................Rocky
That 4ws sure does come in handy. You can use it pretty effectively also "thumbsup" Might have to look into that for the futre.
Harley, I don't know If i'm not looking in the right post or just missing it. But by any chance did you draw up a diagram on setting up the 4ws to the Futaba 4PL . Thank's
Wiring Diagrams
Note: None of these diagrams show the stock lighting controller. It only requires a 4-6v power supply so any open port will work or you can direct wire it off your BEC (as long as you are running appropriate voltage) or your ESC's red RX wire.
Standard stock setup WITH BEC.
Note that you need to pull the red wire out of the plug from the ESC so that you do not burn up the internal BEC in the ESC. Just pull it back and tape it, you will need to be able to reconnect it to program it via a Castle link or Hotwire if your ESC is compatible with that (stock ESC can use a Castle link).
A typical 2 servo system.
Harley,
you may indicate a link where I find the doll / pilot for the wraith?
tanks
Harley, Thank's that diagram was part of it. I think I i was only looking at your Axial Wraith build. But if you do have the programing of the 4PL for the diagram can you throw me a bone. Cause I'm going with the 4WS and the Winch. Thank's again Cheif..."thumbsup""thumbsup"
Thanks for the video. All the rigs were looking rad."thumbsup"
