Antisimplistic
Holy crap. Don't get your fingers caught up in that monster!
You going to try your hand tig welding the shock mounts ?
Those are going to be sweet. Can't wait to see them on the rig. They'll really set it off.
I got an extra set made so I can do one with the MIG and one with the TIG.
I have to get a new hood first though, my existing auto hood is not working for TIG. It keeps flashing me no matter what setting I'm using. Not going to keep risking it with that one. If my hood doesn't show up today I'll probably just MIG weld a set and get them installed.
Something like that for the front would be awesome. Lets see what you can draw up for that one. If they look anywhere near as good as those they'll be bad ass fore sure.
I think I will try a low-tech approach to making something similar. Make it out of one piece and bend into a box structure.
Then braze or solder the joints... I dont have access to a plasma cutter. :shock:
The next thing I did was a tummy tuck. I always wanted a little different setup for the skid plate. Since raising the skid plate will raise the transmission I needed to double check that there was enough clearance between the motor/trans and the interior. No issues.
1/4" square stock drilled and welded in.
The difference in height.
I removed the boat side skins and I will replace them when everything is finished. I will probably do a bolt on Delrin panel to help things slide better as well as hide the skid plate bolts.
Quick question about the tummy tuck since raising the skid plate raises the link mounts wouldn't lowering the shock mounts an equal amount achieve the same result? unless the tummy tuck was done for another reason besides ground clearance. Btw your builds always look awesome.
Tonight was very productive. I went a picked up a welding hood on the way home so that I could try and work with the new TIG.
I got home and went down to the shop to get to work. This was the first time really using the TIG and I knew there was going to be a learning curve. By the end of the second shock tower though, I was very pleased with how things were flowing!
I took a picture of my welds before I cleaned them up. They aren't very pretty yet but with < 1 hour of experience I am OK with that.
