Diving into an optic
Take the tall clamp and slide the bottom surface across a fine metal file a few times until it fits better.
Mine were good. But that is what I'd do to tighten it up, like you said, it don't do much/anything but look good. so it may as well look right. lol
If I get a wild hair I might do that, that’s a good idea.
I decided I had enough with the leaking shocks. Put desert lizards on it, which I cannot stand them but they don’t leak. Can’t leak when there’s no fluid in them! Tried it multiple ways, with fluid and the long skinny spring setup, it was too stiff. Without fluid and the long skinny spring is pretty good for the optic. Time will tell but they are on and they aren’t half bad.
Now, I’m waiting on some lights that I will use for rock lights as there is a local night run coming up this weekend!
Ol optic did pretty well at the night run last evening. No broken parts or carnage. Climbed well, desert lizards seemed to do just fine. I’m always skeptical about them because previous rigs with them were terrible. Randomly unload, wouldn’t extend, etc.
Ran about 3- 2200mah batteries over the course of 3+ hours. I was moving a little faster so the speed was higher only providing about an hour of battery life. I will say this system is not efficient. My sons optic with a stock brushed system went about 2-1/2 hours on 1-2200mah 3s / just like mine.
Highly considering going back to a fusion system.
Didn’t get as many photos as I’d have liked too but had fun nonetheless! Before the night run I added rock lights in the rear for that extra razzle dazzle.
Decided to swap out the micro x and Holmes 10 shooter for a fusion pro. Just wasn’t a fan, not a hater but there’s a reason I have about 10 empty fusion boxes in my rc box collection of junk lol
More wires
Less wires
Also update:
Desert lizards are terrible. I’m sure someone will say they are the best shocks yadda yadda but they are not. Worked fine out of the box and first run. Now they won’t retract when compressed. Ridiculous waste of money.
I really want some new shocks and get rid of these turds.
Also update:
You may want to check out the new Reefs Shocks. They're a pretty good design, and Wyatt has been running them for a while with no leaks as of yet, per Wyatt at Reefs. heh
But they do look like a nice option and if they don't leak or don't leak very much, bonerus.
I’ll check em out. I haven’t seen those yet.
Traxxas GTS shocks. Can get take offs on eBay or Jenny's RC for reasonable price. Even reasonable brand new compared to other aftermarket shocks.
No leak, good quality balls and plastics, fit common Axial, element and VP springs.
Can reduce friction by playing a bit with the seal squeeze. I just saw today that Chingon had post about his AX10 turned comp truck where he talked about this on Traxxas shocks.
Took a look at them, I’m definitely interested in them. They look decent!
Took a look at them
I like those too. Almost picked some up at the hobby shop. Just wasn’t sure about them. Might give a few options a try lol
I'll throw in Element as a good shock absorber brand - I consider them and Traxxas GTS as the best for the money.
It's a bit easier to find new take-offs of the GTS shocks, though...
I agree the element and FT fancy version are good also.
The one thing that bugs me with the element shock over the Traxxas is the looseness of the top pivot ball in the shock cap eyelet. But pivot ball slop drives me a bit crazy and most others aren't so picky (nuts?).
Shocks are the biggest issue I have with crawlers. I usually just keep them factory and let em die on their own.
But, I did get this sweet little cooler for it. It just fits it so well.
And it evens opens with some sodies in it!
Went ahead and ordered some FT shocks for it. I like the look of the air shocks from hot racing but I believe I’ve had them in the past and was unimpressed.
Forgot I have FT shocks on my Knightrunner build and they are fantastic, and that rig is heavy, fast and I abuse it.
Good choice on skipping the Air shocks - those are a complete gimmick, and bad news - people have posted on those here before, a long time ago...;)(y)
FT shocks are installed. Wow, huge difference and they are smooth as warm butter. Can’t wait to put them to the test. Maybe I’ll have better luck on steep off camber climbs, without the shocks unloading or not unloading when they need to.
Good bye desert lizards 👋🏻
This is just setting the truck down. With the DLs with my very advanced measuring device
Now with the FT shocks. 👍
Nice choice on the FT shocks. Hard to beat their smoothness and no-leakability!
Perfect little cooler to hold the cold ones.
Yeah, I should have got them in the first place. So smooth and the finish is beaut!
Was surprised the lid didn’t even pop open at the g6!
