Right before Christmas I picked up the VFD Hurtz DIG. I've been wanting to get one of these for awhile, but they were out of stock. As soon as I heard that VP had them in stock, I went ahead and placed the order. I went with the Clear version to match my clear axles that came with the PRO.
I also picked up the VFD 21% Overdrive Gear Set during the sale that VP was having at the first of the year. I figured while I had the trans out I might as well add in the OD gears.
Here it is all together. It went together really easy and all the pieces fit like a glove. I did watch Harley's install video on YT while I was putting it together. His video was well made and made the installation very easy.
I bought the cheap DS3218 Pro servo off eBay to use for the DIG. I figured I wouldn't need nothing to fancy or powerful to move the DIG switch. I also picked up the VP Clamping Servo Horn 25T 24mm. This is the servo horn that VP recommends.
And here is the trans with the DIG installed. The alum DIG case bolts in without issue just like the stock tranfer case did.
Here is the servo with the VP horn and the link and rod ends that are supplied with the DIG kit. I did have to cut off the little braces that were on the servo mounting tab so that it would fit into the servo mount on the rear chassis brace.
And here the install is complete with the trans/DIG and servo installed. I left the battery tray off that used to attach where the DIG servo attaches. I plan to move the battery down on the driver side slider.
Next up will be moving the receiver and Castle B-Link to the fuel cell in the back of the chassis.
Thanks for looking!
Thanks for looking!
