xr10 with Dlux bounty hunter chassis
Little bit of pregress sorry work has kept me pretty busy but it's finally a roller again only problem is that one side seems droopy not a shock problem more like a link issue anyways enjoy
Rig is looking nice. Love the VP aluminum. Kinda getting hard to find. If you are still looking for colored hdware check Hobby etc.They have a good selection of nuts and screws. Aluminum is also available. What does your rig weigh in at? Mine is at 4 lb 6 oz without trying to do any type of lightening. I also run 2 front axles. What is the advantage to taller/longer top link mounts. Do you have to adjust link position on chassis also? I'm still learning about the suspension on my XR10. I have a 5th Demension chassis. Went with the twin fxr setup on mine. I have a lot of Hot Racing (HR) on mine. Big bearing gearbox, top link mount etc also RC4WD lightened gears (LHS had some ,) Dlux TI links, Tekin 35s going back in. Had trouble with them being too fast in reverse, turns out it was the radio setup. Will definately keep an eye on this thread for further developments. Later
