I didn't use one. The bump steer I got was very minimal.If it starts to bother me I'll come up with something....lol
Hack at it? Hack at what?If your talking about the cutting you'll have to do. It's not a big ordeal. two small tabs, two Small braces between the servo mounting holes, and the ends of the bumper posts. I don't think that's a huge deal when it makes for an almost if not free CMS.It took me all of about 15min. to do everything I needed to do to get the servo mounted.But that's why this is called the "tips and tricks" thread. I gave a tip and told the tricks to pull it off.I love making my own stuff. I like making things that take a little thought to come up with.But that's just me.To each his own.I tryed the diy cms......couldnt do it.not that I couldn't but didn't want to hak at it.just ordered the level 3.
that was still too much heat. i used a hairdryer and a space heater and worked them little by little not letting them get too hot. my rims look brand new with no sign they were ever already gluedThis isn't really a mod. I'm just showing it can be done. It would have saved me over $50 had I known this could be done when I upgraded to beadlock rims.
The Stock tire can be removed pretty easily using a heat gun and some HEAVY leather gloves.
You have to heat up your rims a lot! These pics show you what your rim should and should NOT look like when doing this.
Rims on left= to much heat (could damage tires)
Rims on right are perfect (edge of rims just starting to bubble)
Note: DO NOT point gun directly at tire! Once the rims edge start to bubble break the bead of the tire and tear off the tire. If you are careful the tire shouldn't rip or get damaged. After a couple tires you'll be a pro!
^ probably already stated/posted here !?that was still too much heat. i used a hairdryer and a space heater and worked them little by little not letting them get too hot. my rims look brand new with no sign they were ever already glued
I boil mine to separate the tire from the wheel.
No damage occurs to the tires or wheels... ever.
Even my stock axial foam inserts survived.
The boiling process takes 15 minutes or so
to allow the tire's bead to be pulled off the wheel.
I laid the tire in the sink after it was boiled for 15 min.
then used some tongs to push down on the sidewalls
Patience is a virtue here...
and if they don't separate initially (after the first attempt).
boil them some more.
You don't want to force the issue and tear the tire's bead.
Boiling hurts nothing...
'cept... if the foam insert is already crap.
Boiling the foam inserts (along with the tire/wheel)
is not an assured death to those
but, they could possibly become damaged during the process...
requiring replacements.
Most other used methods of removal could cause damage
to the wheel and/or tire.
btw... boiling rubber tends to stink up the house when boiled.
but not too terrible.
Boiling them outside would reduce the stink inside ;-)
I have used this boiling method for separating
tires from nylon wheels since the early 80's
Was necessary back in my RC competition days.
I did this to my son's RTR ripsaws glued to the stock wheels
just the other day... separated nice and clean.
He's a happy camper having seen the results "thumbsup"
If you have a winch, you can replace the stock string with bead working wire. About $4 for 30 feet. 20 pound breaking strain. Literally is scale tow cable if you ask me.
