SDheavymetal
3 cell Lpo! 35t motor or 30t
This was a pretty rad mod that I found on this site and inspired me to save the $30+ on a hard top and just go for my own on my Rubicon.
http://www.rccrawler.com/forum/general-scale-talk/420797-6-minute-soft-top.html
Strengthen you factory drive shafts with parts you already have!
First find this parts tree and cut the end off where the hex tool is pointed to look like the piece on the right. you'll have to shave the things off the sides too. I used a utility knife for all the cutting.
Next shove into the male part of the drive shaft and cut it leaving just enough to be pulled back out with pliers.
This mod will make your shaft much stronger by not allowing the inner shaft to collapse and twist. It also slightly enlarges the inner shaft making it a close tolerance fit in the outer shaft. Adding a light coat of grease will help them move freely.
so after doing upgrades to my honcho iv got a GCM t-case and front motor mount everything is good but i noticed that after a lil water on my slipper i loose all fuction after a quick stop its fine im running 87/10 and 15 twh motor with 2s is it poor motor or need a slipper bc this one is butter now
After I "Mirrored" ... I added lights and such. Too many wires under the body to get all snagged up.
So I just made a "Spur Cover" out of an adult product can.
Works great, and it was free. Its not my best work, but it works for now.
How to make a track bar for leaf springs with stock 3 link.
First, zip tie the 2 arms that make the y so that they are as close together as possible. Then heat the joint until the 2 arms are close enough together that the screw holds on the top touch.
Then put a screw through the screw holds to secure the y link. I used a spare axle housing. Hold the link with a pliers about 3/4 of an inch from the screw hold, and heat just next to the screw hold, and twist until the screw hold has rotated 90°. Repeat with the the other arm.
Now you have a free track bar. I will be mounting the lower arm to the link/ shock mount, and the upper to a 4 link truss.
Your welcome "thumbsup"
sent from my crappy phone using tapatalk 2
