How will this servo run on 2S?
It is weaker and slower, but seems to work fine with my limited testing on 2s in a sxc10ii.
Awsome servo, I couldn't tell if it was functioning until I turned the wheel... soo quiet, smooth and more pleasure not having to listen to my old hitech 7955 twitch and chatter
Sent from my SAMSUNG-SM-G891A using Tapatalk
You won't be disappointed,it's nice and clean not having to deal with the Bec anymore. Thankyou Holmes hobby you guys knocked it out a the park with this oneI like hearing that the chatter is minimal/gone. Awaiting my order of several of these to switch from Hitec, remove my BECs to clean up wiring and throw in these stout HH servos. "thumbsup"
Thanks for the tip I'll give that a try since my other honcho is still rocking hitech's and bec'sIve found adjusting the deadband to about 4 helps a ton with chatter on my hitec, but loving this my HV500 servo, thanks HOLMES
That is great to hear. I will have to try that with my existing Hitec servos and pass that info along to others in my group. "thumbsup"
Guessing the deadband on the HH cannot be adjusted.
Not yet. We are still working on a programming interface, right now it is all hard code changes.
John - can the new servo be ordered with the wiring, soldering, and connectors set up already if you also order a Combo at the same time?
I need to order a Puller Pro, CC Mamba Monster X, all connectors, wiring, soldering done and also the servo wired into the battery wires so I can just install as is into a Bomber kit that is coming Thursday.
I'm willing to pay for all parts & labor, of course - just need to enter it all into your site and pull the trigger....
I was only semi-decent at soldering when I was young and unfortunately have a tremor issue and lousy close-up vision these days.
