Theutrich
Thanks, yeah I get the theory that kv is the back emf in volts of a motor at an rpm if used as a dynamo, and as such is the theoretical output rpm when a volt is applied with zero load. And that kt (torque) is the inverse of kv for a given motor constant km. It seems like it's basically an "electrical gearing" (where you are trading speed for torque) before actually getting to physical gears, which then can further exchange speed for torque. I just don't have experience with how the actual numbers (2850kv, 2280kv) anchor them to relative performance.
In theory whatever kv I pick, I could adjust the speed/torque with gearing. But in reality pinions can only get so small, and spurs can only get so big while fitting in a gearbox. I'd hate to get too fast of a motor and be forced to put the smallest pinion possible and the biggest spur possible for decent lowspeed control -- and then have no wiggle room, or worse, just run out of gear range and it's still too fast. I'd rather have a motor speed that gives me some wiggle room to gear in either direction until I like it. Since there's a lot more room to gear up than down, I think I should err on the low-kv side, if that makes sense?
For that thought process, I'm looking at the castle 1406-2280kv motor. (I would get a puller pro, but castle is out of stock on everything so I have to get the mamba x through amazon and amazon only sells them paired with castle motors) Since I have no experience with these motors, or for that matter adjusting gears, I hope the 2280kv isn't too fast and I end up wishing I went with the 1900kv. I just worry that's TOO slow. It's a very scientific guess of, "slow but not the slowest thing there is, so second slowest".
