I will admit, right now, I'm slightly confused. In your initial post, you stated the servo was a 3-wire servo, which would indicate it's designed to receive power from the Rx. However, the wording of your second post (post #3) is worded in such a way that it makes it seem you have a "direct power" servo...which would actually be a 4-wire servo (ie. + & - for power from battery going to one connector, and then a signal & - wire going to the JR connector for the Rx). Which is it? Maybe that's why our replies don't seem to be helping you - because, in your comments, you've actually referenced two completely different servo wiring configurations. From the beginning, it would have been helpful if you posted a photo of the servo, so that everyone attempting to help you would know what the actual servo is.
Sent from my SM-X818U using Tapatalk
This is not a direct power servo. It does not have a power lead on it.
The fact is no RX can handle 12.6 volts run through it anyway.
That is why I need to utilize the HH's by-pass wiring.
I never mentioned a JR connector or plug. And if I did it was a typo error.
I did mention using JST plugs though !? But those were before I knew of this HH's by-pass method to/through the RX.
I will simply use the JST plugs to supply my voltage regulators with the necessary voltage for each component.
The servo does not have a name. It is an industrial servo mfg'd in China.
But if 150 KG can't turn these wheels ? I'd be shocked !
Granted I'm rolling near 50 LBS on this behemoth now ! Thanks to all these Vitavon alloy components I have on board.
It'll likely be closer to 60 lbs when I'm done.
So got to make it strong if I hope to keep it in one piece.
The Vitavon driveshafts weigh in at a tad over 1 lb by themselves !
This is not about the costs associated. But about doing it right from the start 8)
Sorry I didn't post pictures. I really don't have that tool these days.
Lost that ability when Photobucket tried to extort me ! And it's too late for me to start over
