johnrennainc
Which servo horn do I use
Sent from my SM-T820 using Tapatalk
Something I just noticed.
Just finished putting the chassis together today. Wondering if I missed a step or part. The dig arm is rubbing on this screw head. Works fine, but needs a little clearance.
I just looked at mine. It's tight, but they don't touch. Is the screw all of the way down?
Here's something else you should know. Pay attention when you are assembling the transmission. When you get done and there is 1 E-clip sitting on the table staring back at you, you aren't going to be too happy. Trust me on that.
Seriously zooming in on the photo (34" monitors are great for this), I'd estimate the screw is approx 0.5mm short of being fully seated..That was my question. It doesn't look like his screw is completely tightened.
I just checked, I was able to get about a 1/4 turn out of it, but its tight and the arm still rubs. I'll have to pull the link mount to see if it didn't seat correctly and of course, it's buried now. I'm sure this is still my fault in some way lol
Did you happen to mix up the short and long screws that hold on the link mounts?
No the screws were the right length. I removed the link, counter sunk the i/b hole and reinstalled with a new screw. Arm still rubs on the link. I'll probably just add a washer under each center skid trans mount.
New guy here but not new to rc, I finished my 10-3 and love it, great kit, I encountered the minor typo issues and the shock tower alignment issue (which I’m sure they will address) which weren’t big deals. However I do have a question, I have the same constant clicking in the transmission (I believe in the trans) that can be heard in most YouTube videos of the 10-3, but mine does seem less pronounced. My question is has anyone investigated this yet and or found the cause? Thanks in advance !!!
Has anyone else had an issue with clearance between the servo horn and chassis? I'm using a Spektum S6280 servo, and had to file on the chassis, lower edge of shock tower and horn itself a bit to make it move more freely. I don't think it will be an issue now that I filed it down, but may file down the mounting tabs on the chassis brace servo mounts to gain some more clearance.
