2mtech
C1 #3 hardest!
C3 bottom of page
Hang up and Drive
I see...thanks! "thumbsup"
C1 #3 hardest!
C3 bottom of page
Hang up and Drive
So...if any of us has problems with building the trans, do that mean we can send them to you? [emoji849]My paranoia made me tear my transmission down again instead of going to bead at 11:30 last night. Every E-clip in the instructions was installed. Whoever put that extra clip in the bag has cost me sleep, but made me somewhat an expert on this trans.
I do kind of miss the simplicity of the 3 gear trans that I could tear down and build back with my eyes closed.
Is anyone else having issues with the shock tower mounting holes lining up?
I did have problems. While the other end was lined up perfectly, this is what all my shock towers looked like on the other end:
I had to take my hobby knife to the holes and widen them towards each other. The countersunk screws don't quite line up with the hole, but that's only a tiny cosmetic booboo.
Did anyone else have this?
My paranoia made me tear my transmission down again instead of going to bed at 11:30 last night. Every E-clip in the instructions was installed. Whoever put that extra clip in the bag has cost me sleep, but made me somewhat an expert on this trans.
Heads up on the driveshafts, Rich noted the typo, What bothers me is the pin screws for the caps are in two bags , as they get installed separately.
The other two are in parts bag F, used in F8 and F10
Hey Rich. Minor typo in the parts explosion on page 56. The part number for the hood vents should be AXI230022.
For others: there are 4 black decals that you may be left over with on your sticker sheet when you’re all done. These wrap around the rear tail light lenses and are easier to apply before bolting them into the body. If you look carefully there’s a bit of an outline on the lens for the one that wraps vertically.
Thank you! I was looking at those last night wondering where they went.For others: there are 4 black decals that you may be left over with on your sticker sheet when you’re all done. These wrap around the rear tail light lenses and are easier to apply before bolting them into the body. If you look carefully there’s a bit of an outline on the lens for the one that wraps vertically.
Edit: I just found the extra pan hard mount in the body mount bag, I take it if I used this one I would have had less trouble on that part of the build?
Edit 2: Never mind, the extra pan hard mount looks like it’s for a different build version.
How about the rear view mirrors? They call out 2.5x6mm button head, but image displays countersunk?
You use the cs, the spacers are for countersunk also the button heads are used to hold the wipers onHow about the rear view mirrors? They call out 2.5x6mm button head, but image displays countersunk?
Anyone know/has link to US supplier that sells these? I found a few on eBay but all they say is “M3”
This is my first kit build. When I bought the kit online it listed needed parts (servos) also optional accessories. Are these bearings needed or are they extra?
Day 1 of my first build down. The biggest headache so far was the E clamps of the shocks. To start off I thought I was shorted one and went crazy looking for it. I finally found it stuck to the bottom of one of the stainless pivot ball for the top of the shock. Once I found it, I lost it again when it shot out of my hand and pliers while trying to put it in place. It cleared about 12 feet from where i was. Thankfully I was able to find it again and get it together.
The transmission was interesting. One suggestion for the newer builders is maybe have some color or making indicator to separate the bearing sizes. A few were so close I had to pull the transmission apart a couple of times. Can't wait to start day 2..
