I'm going to today. It's driving me nuts. Need to debug the exact place where this happens and see how to fix it.
One thing might be just to loosen all the transmission cover screws a bit, since I used a powertool with them (such very long screws omg).
...maybe the engines got a bad rod bearing:shock:
"chamfering" the dig and shift threaded attachments can you explain please and why was it needed ?Noticed an area of confusion...... when mounting the transmission ears, make sure the passenger side is installed before all others, the screw is blind after the lower plate is installed.
I also recommend chamfering the dig and shift threaded attachments and prethreading them.....
Hang up and Drive
Has anyone else had an issue with clearance between the servo horn and chassis? I'm using a Spektum S6280 servo, and had to file on the chassis, lower edge of shock tower and horn itself a bit to make it move more freely. I don't think it will be an issue now that I filed it down, but may file down the mounting tabs on the chassis brace servo mounts to gain some more clearance.
My lever seems a little bit too tight even with the pivot screw backed out a bit
please picWell the clicking was still there after installing it and putting tires on the ground. I’ve been thinking about it, it’s approx 3 clicks per rev of the driveshaft.
There is clicking with dig/rear output removed (fwd only)
There is clicking with transfer case gears removed (rwd only)
There is clicking in both high and low
There is clicking with motor/pinion removed and a load on trans
What does that leave?
Only the 2 27t gears up front
The bore of the gear (both) is not parallel to the OD of the gears, as they rotate the pressure being at a angle now is making the gears slide on their shafts clicking as they hit the bearings.
I added a .2mm shim to each shaft, and on the bench installed, under enough load to wrinkle the sidewalls and overload the HW1080 there is no more clicking.
If it’s not raining here tomorrow I’ll get out and run it a couple packs, if raining I’ll beat on the drivetrain indoors on the carpet and see how it does!!!
I drove it a lot today and it’s still doing great, I plan to pull it back out in the next couple of days to inspect. When I do I will take pics.please pic
Got up to finishing Step F yesterday.
I did not have a m3 tap to use for the shock towers to mount the shocks, so I did something different.
I took the supplied black grease and squirted a little bit into the hole. After that the screws seemed to go in just fine without fear of breaking them while still being very snug and tight.
I did thread the hole with just the black grease and screw first before mounting the shocks though.
