soze
Some more corrections for the manual.
F4: M3X12mm countersunk = x6. Parts legend says x4, but the diagram shows x6
F6: M3x12mm countersunk = x4. Parts legend says x2, but the diagram shows x4
F7: M3x10mm countersunk = x2. Parts legend says x4, but diagram shows x2
EDIT: It seems the above is now corrected with the latest revision of the online manual. I was using the initial release online manual.
Something I also noticed.
The panhard mount on the axle has a bigger hole from the front-side than the rear. Intuitively, I would think that the panhard bar mounts from the front of that mount, but the manual says it mounts from the rear. I checked the panhard clearances while cycling the suspension mounting it as the directions say from the rear and it works fine. It just is strange that the hole is bigger on the front-side than the rear before mounting up the panhard.
