THIS PRODUCTS IS NO LONGER OFFERED BY NCD. NCD IS NOT IN BUSINESS.
Sudu One FL
The SuDu One FL is a Face Lift version of the original Sudu One high performance chassis for the 2.2 Shafty and Sportsman classes.
The chassis is made out of 2mm carbon fiber and the base chassis weighs in at 64g. Hardware is is mix of aluminum and steel. The chassis will work well with both AX10 and AR60 axles. Recommended shock length is 90-95mm.
Sportman Bodiless Chassis Options
There are two cab designs available. One with a squarish topper and one with a more rounded profile. Please specify which one you are interested in.
Sudu One Accessories
Lower links
Delrin or titanium lower links available.
Rod ends are not included. Suitable rod end is the Traxxas Revo rod end, TRA5347.
Pics of Ti links coming soon.
4-Link Plates
Front 4-link #1
This plate gives you three optional positions to mount your servo. The servo can be mounted in the middle of the plate or at either end. With the servo mounted to the side there is plenty of room for your battery on the other side. This 4-link plate is a good choice if you are looking to set up a BTA steering as it frees up a lot of room behind your axle.
Front 4-link #2
This tray allows you to mount your servo and small size battery (3S 400mAh lipo recommended) under the plate for a low center of gravity. This setup also allows for a BTA steering setup but is more challenging to set up.
Rear 4-Link
