bob1961
well did some body work, plus made my new Interco IROK tires a bit softer....reading another thread on RC4WD tires that they have a bead down the center line inside that makes the tire hard to conform to terrain....used my dremel with the 1/2" sanding drum on it and it only took me bout a minute each tire....the bead before and after and did it make a big difference....
then a seam web that stayed between the center lugs with the IROK's had to be removed as well....
only way to get it done was to get my finger tips in there and yank them out, i had 6 of these tires to do....
started to hack up the two clod body's to make it fit the 12 3/4" by adding an 1" to the wheel wells, plus it makes the 4.65" tire size of the IROK's not look like 54" tires on a 1:1 rig....
the 1" strip in it's place....
i didn't cut the bed in half yet as i'm still thinking how it will be done with the drop bed i'm going with but there are the 1" strips that will go in....
cut the body with thread for the first time and like how it does a neat job....i found some denim thread that can take twice the beating regular thread can....i went to break this thread with my hands and also most cut my hand....had to hit the switch on my bench grinder and shut it off and hit the thread to cut it while it was spinning..........bob
