Marc's XR10 "The little Tank"
Swiss Rock Force
Switzerland
Hi all,
I like to introduce myself and my XR10 build.
I live in Switzerland and I started with RC rock crawling in spring 2011 with a Kyosho Rock Force. After the first season I changed to my XR10.
Here are some facts about my rig:
- XR10 axles with RC4WD HD gears (3mm drilled for less weight)
- VP motorplates, gearboxes, link mounts, knuckles and knuckleweigths with additional rings
- Lower titan links from Chaotic Crawlers
- Upper carbon links (custom made of 4mm carbon)
- Alu screws and nuts from Fastener Express and alu balls from Chaotic Crawlers
- VP alu wheels (drilled for less weight)
- Closed cell dual stage foams from Crawler Innovations
- HB Rover white tires
- BWD delrin motor savers from Crawler Innovations
- Team Brood Apocalypse T35 Type "ST" motors
- Orignal XR10 Skidplate with custom made carbon chassis parts
- Parma x-citer body cutted down to 24g
- Hitec HS7950-TH servo with Castle 10A BEC
- Tekin FXR ESC
- Punk Dig (something for the museum :roll: )
- SCX10 shocks with plastic shafts
- Losi mini T soft springs
- Battery holder made of lexan (1g)
- Steering link from custom made carbon for more steering angle
Actual RTR weight is 2098g or 4.63lbs.
The first tests of this setup were really successful. So I hope it will bring good results this season.
Here are some pics of my rig:
BR,
Marc
file.php
file.php
file.php
file.php
file.php
file.php
file.php
file.php
file.php
file.php
file.php
file.php
file.php
hi Roxx,
Thank you.
We have really cold temperatures in Switzerland during winter. But I will try do make a video as soon as possible. without getting ill :mrgreen:
dang looks great so light what about making the front the same as to rear? might have to use your idea if you dont mind, i dont think i have the skills like you though.
the reason, why the front shock is laying flat is, because of the height of the body. the body is mounted that deep, that i can drive on even when the crawler is upside down. this way i can avoid a few rollovers.
no problem if you like to use this idea :mrgreen:
Hi marc if you feel like it we do have a comp here in the netherland on the 27/01 . Here the weather is ok ;-)
hi Roxx
Thank you for the invitation. But I would prefer to come to a comp in netherlands from spring to autumn. I think you guys have some comps then, right? if you know the dates, you can post them.
Marc
ups :shock: thanks to all for your positive posts! i didn't expect a reaction like this...
my plan is to visit a big comp in the USA. i'm not sure if it is already possible this year... but I try my best. I really want to meet the worlds best crawlers :mrgreen:
Marc
