As promised I violated my Venture and stole the Savox 2290 servo. I also assaulted my SCX10 II and stole the Mamba X ESC. The Mamba Monster X won't fit in the stock spot without cutting off the servo mount standoffs so I checked to see if the Mamba X will fit and it does. I contacted Robert from Castle to ensure the X was up to the task and he said it should be fine. So the Monster X will be saved for another build or maybe sold. It seems the Mamba X is plenty for the RCs that I have. I don't have 1/8th scale monster trucks, buggies or truggies.
I installed the Rock Rey servo horn from Exotek. I have to say this is the first time I installed a servo horn on a servo and it was in the correct location. I wouldn't need to use much trim at all! I was giddy, but I should have known it's never this easy.
The Exotek servo horn has a lot of meat around it for a clamping, or pinch, screw. This extra meat causes it to hit the aluminum servo mount. The Exotek instructions tell you to hack away some of the plastic on the stock mount. Since I went with the aluminum mount I'm not going to cut anything unless I absolutely have to.
Back to the drawing board. I ordered the Losi version of the aluminum servo horn for the Rock Rey. It does not have a clamping screw and appears to be much thinner. I'm hoping it clears the aluminum servo mount.
The drag link from the servo to bellcrank is freaking plastic. Another hokey engineering decision especially since it has a servo saver built into the bellcrank! WTF? If the Rock Rey had been designed after the acquisition of Axial I would blame them, but that happened after the Rock Rey so Losi is entirely to blame here. I will need to source rod ends and a link to beef up the drag link. I place an order last night on eBay and I also ordered some wires and stuff on RPP this morning. Now I wait as do you guys.
