Night 2 of wrenching.
First up is the SSD bulkhead diff housing. As always is the case with SSD products, it's pretty. This moron was working in light that was too dim for his old eyes and therefore he didn't see the single screw holding the bulkhead halves together. I was wondering why I couldn't pull it apart. Luckily I didn't use any force. :roll:
In a previous post I mentioned en-biggening the holes in the ring gears to install larger, mo-better diff screws. Here's a comparison of the Traxxas screw on the left (2.5mm, fine thread) to the stock screw on the left (2mm, coarse thread).
Dem lil' 2mm screwz iz two small for dat there darn 1/8th scale rig!
Ring gear holes enbiggened and mo-betta screws installed. As you can see the screws don't sit flash with the ring gear because the larger heads won't fit in the countersunk holes, but it doesn't cause any clearance issues like this.
Here's the diff installed in the SSD housing. I think it's crazy how the stock diff halves are held together by two, spindly screws and nuts, but the SSD housing only has 1 screw holding it together. I'm guessing other parts will hold the bulkhead halves together, but I guess I'll find out.
I'm used to removing plastic parts from sprues, which I haven't had to do for this build (Awesome!), but I did run into these odd, plastic barrels in some of the plastic parts.
The front suspension link mount has two of these plastic spacer barrels - one on either side. They have to be removed, but I just found them oddly interesting. It's something I've personally never seen with plastic parts.
I won't be using the stock part anyway as I purchased the Boom Racing piece. I choose Boom because it was cheaper that the Losi aluminum option part, it has an extra set of holes for more adjustability and it is black and looks much better than the clear anodized or grey aluminum. Boom Racing part on the left and stock on the right. The bottom two sets of holes are in the same location as the stock part with an additional row of holes above those.
Here is the Boom suspension link mount installed on the SSD bulkhead with the chassis top plate sandwiched in between.
In the photo above you can see the hinge pins captured on this side by tiny C-clips. These terrified me just looking at them. :shock: I was sure I'd lose at least one of them as it went shooting across the room at 100MPH. Thankfully, that didn't happen and they installed without much effort. But C-clips suck and these hinge pins should be captured in a more modern way with a plate or screws.
