As I get closer to the finish and as we move closer to Christmas the build is moving a little slower.
Up next we have aluminum upgrades from Losi - rear shock mounts and these other small pieces that came with. It took me a minute to figure out what those small pieces are for. More on that later.
Also have the Boom upper link mounts that were packaged together with the lower rear link mounts.
As I said above, it took me a minute to figure out what the small, aluminum pieces are used for. I thought they would be the sway bar mounts, but it didn't have a slot cut into them. So I compared the aluminum parts to the stock parts and it became clear. The small pieces go underneath the large piece to create one solid piece that mimics the stock, plastic piece. I understand this was done to cut costs, but it's a ghetto solution. Not a fan of this at all. There should at least have been a notch and tab in the mating parts to align them. No such thing so you have to eye it up and hold it while tightening the screw.
Once it's installed you can better see what I mean. It seems like it will work fine, but I would have been happier with one piece.
You can see the Boom upper link mount underneath of the Losi pieces.
Oh and for the lower swaybar mount you are stuck using the stock, plastic piece as you can see in the photo below where these are mounted to the chassis. :roll: The parts are too expensive for this IMO.
I will caution you that if you are reading this build before you start building a kit (probably a rare occurrence since Losi killed the kit :evil
you will want to ensure the nuts for the link do not fall out. I installed the left side mounts and then the nut fell out. So I had to disassemble it and I held the nut in place with the screw.
At this point I have to question if I'm building a Rock Rey or a Batmobile. I'd be fine with the Batmobile, especially if Kim Basinger was in it (SCHWING!!!). I dated myself with those last two things. Getting old sucks, kids. People tell you it sucks, but they don't warn you how bad it really does suck! Do not get old! You have been warned. :mrgreen:
In this photo you can see that I've been boned by T-Bone again. The piece is formed wrong and the holes were countersunk on the wrong side. As a result, the top two holes do not line up with the chassis. I've had bad experience with T-Bone in the past, but I gave them another chance. I emailed them about the issue and haven't received word yet, but it is coming up on Christmas and I've read that they are Bible bangers. From what I've heard T-Bone has gotten their stuff together and they will stand good for it. To be continued.
Oh and one last thing. Pennsylvania is now a rain forest, for some odd reason, but it subsided enough to get a picture of the sexy Vanquish axle in natural light. SCHWIIING!!! There's that getting old thing again...
