Help building my Krazed Un-stuck crawler
Big Thank you to Snapon boy for the phone call to get me squared away. Was close to running away with my tail between my legs on this build.
Sent from my S7 using Tapatalk
No worries I had loads of help with my shafty from Winnerone23 and bmachinerc and crucial and lots of others.
149 r/c worx's Team Driver
Rear, keep axles but replace tubes with aluminum ones and vanquish red scx10 lock outs cause I'm ocd lol
Front, axial front universals # ax30563, brass xr tubes and keeping the front vanquish wraith parts I have.
Or I'll trade you I've got a set of non splined aluminum ones. There used tho. But it would save you money.
I would but I really want the splined ones. Are the ones in the photo the right ones to order if i want brass up front and aluminum in the rear?
I honestly don't know if the scx10 lockout will slide over the splined tube you have in the picture. I think if you want tubes in the rear you need stock beef tubes for the scx10 that don't have splines. However I may be wrong.
These will work with ur aluminum ones?
http://www.rpphobby.com/ProductDetails.asp?ProductCode=VPS01190
Edit to add, now that I look at it I think your right. I'll do the trade with you if you want , as long as it works with the ones in the rpphobby.com link
Do I gently tighten the bushing screws (king pins) down till they just touch the brass? Use lock tight? The screw, bushing and c-hub stay fixed right, the knuckle slides around the bushing?
Feel free to PM me, for any knowledgeable info, you need..
Set Screw's will work. Just loc-tite them..
No need to tighten them down. Snug will do
Plus. You would do better, to have this moved to the AX-10 scorpion section
