lonewolf8o
Big Thank you to Snapon boy for the phone call to get me squared away. Was close to running away with my tail between my legs on this build.
Sent from my S7 using Tapatalk
Yes but if I wanted tubes in the back I can use what I already have right? or change over to the aluminum one like in the above photo?No tubes for the rear. Xr wide for the front. Is how I'd do it. But that me
149 r/c worx's Team Driver
I would but I really want the splined ones. Are the ones in the photo the right ones to order if i want brass up front and aluminum in the rear?Or I'll trade you I've got a set of non splined aluminum ones. There used tho. But it would save you money.
These will work with ur aluminum ones?I honestly don't know if the scx10 lockout will slide over the splined tube you have in the picture. I think if you want tubes in the rear you need stock beef tubes for the scx10 that don't have splines. However I may be wrong.
Awesome ok, thankshttp://www.beeftubes.com/store/p55/SCX10_Beef_Tubes_-_U4_-_Aluminum.html
This is the type of tube that will keep you at the stock width and work with the Vp lockouts you want. If you can wait until tomorrow I have an idea that may help you and save you money but I need some time to test my idea before you buy something and it dosnt work out.
Lmao, thanks. It does screw in the other way but "looks like" it would have the axle (which I don't have yet) pointing downward.You'll find out for sure as soon as you try putting the screws in the bushings. [emoji38]
Yes top is correct.
Feel free to PM me, for any knowledgeable info, you need..Do I gently tighten the bushing screws (king pins) down till they just touch the brass? Use lock tight? The screw, bushing and c-hub stay fixed right, the knuckle slides around the bushing?
